Linux Users
Trying to get USB-6009 to work on Ubuntu 22.04.5 LTS, but getting DAQmx Error: Device identifier is invalid
Hello dear people,
I'm trying to get started with the USB-6009 device on Linux Ubuntu 22.04.5 LTS. I installed the drivers and tried to run the example "ContAcq-IntClk.c".
It compiles properly, but when i try to run it i get the following error:
$./ContAcq-IntClk
DAQmx Error: Device identifier is invalid.
Device Specified: Dev1
Task Name: _unnamedTask<0>
Status Code: -200220
End of program, press Enter key to quit
I tried modifying "Dev1" in the call to "DAQmxCreateAIVoltageChan" into "Bus 001 Device 008" but i get the same error.
lsusb shows the following output:
Bus 001 Device 008: ID 3923:717b National Instruments Corp. USB-6009
Any ideas how to fix this?
Thank you very much in advance and kind regards,
Jakob
(980 Views)
According to NI Hardware and Software Operating System Compatibility, USB-6009 is unsupported in Ubuntu.
As a matter of fact, almost all USB DAQmx devices except some USB cDAQ are not supported in Linux Desktop.
https://tmesystems.net/
(966 Views)
I am facing the same error with NI USB 6501 and NI Linux Device Drivers 2025 Q1 on Ubuntu 22.04.02. Is there any progress on that or a workaround?
(804 Views)
The roadmap stats that there should be support now:
https://www.ni.com/de/shop/software-portfolio/platform-roadmap.html
But it is not working for me using Ubuntu 22.04 (Kernel 6.8) and USB-6421. Is this false advertisment? Or what is the problem?
In times of KI programming, there should not be any reason why a driver can not be translated from windows to ubuntu. 😞
(721 Views)
It is not a false statement. I don't know what is the reason behind it but all NI USB devices (except for USB cDAQ) are excluded in the NI Linux device drivers since the release in 2018. I don't think they are going to support USB devices in the future as well. You can try reaching out to them and submit a feature request but I don't think they are going to make it happen unless you have a big business potential.
(714 Views)
I will ask where I can send the device back. I only bought it because I wanted to use it with a Jetson. And the Jetson runs ubuntu.
Can anyone recommend another manufacturer of a good DAQ that works with ubuntu and usb?
(664 Views)
Try Universal Library for Linux® - Digilent Reference
(654 Views)
