Linux Users
USB-6009 support in ni-daqmx 18.1?
I'm pretty new to linux, and to NI. I have a USB-6009 and I would like to use it with linux. The readme for the NI-DAQmx 18.1 linux driver doesn't seem to list any USB devices, so I was wondering if it was even possible to use the USB-6009 in linux.
Is my only option to use the very outdated DAQmxBase 15? That would require that I downgrade my OS and mess around with 4-year-old libraries.
(7,283 Views)
Accepted by topic author majesticerik
At the moment, there is no ability to use any USB DAQ hardware with the newer DAQmx drivers on Linux.
DAQmx Base 15 is the currently the best/only option for using that hardware in Linux.
Check out the DAQmx Base compatibility matrix though. It should support the current versions of CentOS and RHEL.
(7,266 Views)
Thanks. I'll have to look at switching from SUSE. I wasn't aware of that matrix.
(7,258 Views)
Has Linux support enabled USB device recognition since the Jan 2019 posts saying it was not available yet?
Specifically should nismbioscached work and create the USB device table in /run/nipxips/smbios/smbiosdmp ?
If yes, what opensuse version and ni-daqmx version?
I am on openSuse 15.2 and ni-daqmx version 20.1.
(3,759 Views)
