Linux Users
gpibprtk kernel module
All of the USB devices supported by NI-DAQmx Base are user-mode drivers so they will work on distributions with newer kernels.  NI-DAQmx for Linux currently doesn't support any USB devices.  So really the only support we lost was for the GPIB-USB-HS and GPIB-USB-B.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
Message 11 of 13
(924 Views)
Pls.can confirm that actually i can't use GIPB-USB-B and GIPB-USB-HS on opens suse 11.
If i can't use now in the future this problem will solved or not?
Message 12 of 13
(924 Views)
You can not use the GPIB-USB-B or GPIB-USB-HS on openSUSE 11.0 or later using any of the drivers that National Instruments provides today.  However, you may be able to use these devices using the third party open source drivers provided by the Linux GPIB Package.  Of course since these are third party drivers National Instruments does not officially support them and any support requests should be handled through the community.
Maybe?  Supporting these devices on new Linux versions requires a complete rewrite of the drivers.  If the demand for officially supported drivers for these devices on newer Linux distributions is high enough then we may rewrite the drivers at some point in the future, but at this point no plans have been made.
Shawn Bohrer
Message 13 of 13
(924 Views)
