Linux Users
increase default font size
I am  using LabView 2009 (Linux). The fonts are too small and so are the vis. Is there a way I can increase the default font size?n Is it possible to make the vis a little bigger?
I know one can increase the fonts by Ctrl++, but I dont want to do that every time.
Thanks.
-H
(3,837 Views)
You can configure the default fonts in the Tools->Options dialog. This will affect any VIs which use the standard fonts (Application Font, Dialog Font, System Font, etc.), but not if they used custom font settings. Most VIs use a standard font, though.
(3,321 Views)
