Linux Users
libnipalu.so failed to initialize openSUSE 11.2 nidaqmxbase-3.4.0
Yes, I tried to install DAQmx before DAQmx Base, but I didn't find any program like VISA Interactive Control. Does they exist or how can I interact with device by DAQmx?
Another questions:
- how can I delete DAQmx to use DAQmx Base without problem? And can I use DAQmx without deleting DAQmx Base?
- what differences between them (why are you recommending DAQmx (not base))?
Sorry for the noob questions and big thanks for your help! You helped me a lot.
Message 21 of 23
(596 Views)
DAQmx for Linux is a port of DAQmx for Windows.  DAQmx is more fully featured, more widely used, and more widely tested compared with DAQmx Base. If your use-case allows you to use DAQmx, I would highly recommend taking advantage of it.
I already gave you the commandline that gives you the DAQmx recognized devices (nilsdev).  Please use that utility as well as the resources installed by DAQmx to configure and test the card.  I would also recommend searching on ni.com if you are unsure which utilities are available or how to use them.
Message 22 of 23
(596 Views)
Hello, StevenT. "nilsdev" detected my device and I successfully used some C examples. Big thank you for help!
Message 23 of 23
(596 Views)
