Linux Users
libnipalu.so failed to initialize when open visaconf in konsole
hello everybody
when I open visaconf in the fedora 23, it can give me the following error:
perhaps you need to run updateNIDrivers
Aborted(core dumped)
can anyone help me to solve this error and any help would be appreciated
thanks
yeliu
liuye@xao.ac.cn
(6,665 Views)
Did Yout try to run updateNIDrivers utility as a root?
I had similar problem (here). I ran out of memory durig compilatoin of drivers but, anyway,
$ dmesg
command was very helpful for me. I think that Fedora is not supported Linux from NI.
(6,650 Views)
Hi, thanks for your reply. I have two question, hope you can help me.
First. How to run updateNIDrivers utility as a root. Secondly. what should I do when use the dmesg command
(6,614 Views)
1. Try this command and in case of any error, send the output from console ...
sudo /usr/local/bin/updateNIDrivers $(uname -r)
You must have Linux headers installed, before running update drivers.. I don't know how to install it in Fedora. Maybe something like yum -y install kernel-devel kernel-headers
2. output from dmesg command contains very useful information about running system. So in case of troubles, dmesg can give some hints.. but for now, you don't need to use it.
I recommend to install one of the supported Linux. Centos, openSuse, ...
Good luck!
(6,610 Views)
I am on CentOS and tried this (including ensuring that I have the right kernel-devel and kernel-headers), but got the following error:
nikal: ERROR: Error locating kernel sources for the requested kernel version (3.10.0-514.el7.x86_64)
Any ideas?
(6,460 Views)
