Linux Users
libnipalu.so failed to initialize
updateNIDrivers works fine. But when i run ./daqtest it shows th follwing error.
Perhaps you need to run updateNIDrivers
Aborted (core dumped)
I'd really appreciate your help!!
Configuring NI-KAL for kernel version 3.10.0-229.el7.x86_64...
Building module nikal...
nikal successfully updated.
Building module nipalk...
nipalk successfully updated.
Building module niorbk...
niorbk successfully updated.
Building module NiViPciK...
NiViPciK successfully updated.
Building module nidimk...
nidimk successfully updated.
Building module nimdbgk...
nimdbgk successfully updated.
Building module nimxdfk...
nimxdfk successfully updated.
Building module nipxirmk...
nipxirmk successfully updated.
Building module NiViPxiK...
NiViPxiK successfully updated.
Building module nipxigpk...
nipxigpk successfully updated.
Would you like to reboot now? [yes|no] no
Please reboot manually before attempting to use your NI drivers and products.
(3,729 Views)
From your kernel version I'm guessing this is RHEL 7.1.  Have you done a "yum update" to make sure your kernel version & kernel headers version are in sync?
(3,712 Views)
I did a yum update but again the same problem.
(3,701 Views)
Have you tried uninstalling those older NI drivers and updating to the 2018 NI Linux drivers?
http://www.ni.com/product-documentation/54754/en/
(3,693 Views)
