Linux Users
ni-rio-driver could not be installed on Ubuntu 20.04
I installed ni-rio driver on Ubuntu20.04.
The installation appears to have been successful.
But I can't find the ni-rio and ni-rio-server files.
Where are ni-rio or ni-rio-server files/folders?
How to install ni-rio driver on ubuntu?
I tried to install the ni-rio-driver using NILinux2024Q3DeviceDrivers.zip.
install ni-rio
$ sudo apt install ./ni-ubuntu2004-drivers-2024Q3.deb
$ sudo apt install ./ni-ubuntu2004-drivers-stream.deb
$ sudo apt install ni-rio*
apt list ni-rio
$ apt list ni-rio*
ni-rio-dkms/unknown,now 24.5.0.49322-0+f170 amd64 [installed]
ni-rio-fpga-ids/unknown,now 24.5.0.49314-0+f162 amd64 [installed]
ni-rio-labview-2022-support/unknown,now 24.5.0.49322-0+f170 amd64 [installed]
ni-rio-labview-support/unknown,now 24.5.0.49322-0+f170 all [installed]
ni-rio-mxie/unknown,now 24.5.0.49288-0+f136 all [installed]
ni-rio-niriochinch-dkms/unknown,now 24.5.0.49285-0+f133 amd64 [installed]
ni-rio-niriomt-dkms/unknown,now 24.5.0.49321-0+f169 amd64 [installed]
ni-rio-server/unknown,now 24.5.0.49322-0+f170 amd64 [installed]
ni-rio-sysapi/unknown,now 24.5.0.49321-0+f169 amd64 [installed]
ni-rio/unknown,now 24.5.0.49322-0+f170 amd64 [installed]
lsni -v
$ lsni -v
Scanning localhost for devices...
System Configuration API Experts found:
NI Device Interconnect Manager 24.5.0 (nidim)
NI-CONTROLLER 24.5 (ni-controller)
NI Network Browser 24.5 (network)
NI MX Routing Utility 24.5.0 (nimru)
NI-MXI 24.5 (ni-mxi)
NI PXI Platform Services 24.5 (ni-pxi)
NI-QPXI 24.5 (ni-qpxi)
NI-RIO 24.5.0 (ni-rio)
NI System Configuration 24.5 (nisyscfg)
NI-VISA 24.5 (ni-visa)
This result of "apt list ni-rio" shows that ni-rio is installed.
$ ls /usr/local/natinst/
LabVIEW-2022-64  lib64      LVComponentLocationInfo  nilvcli            share
LabVIEW-2024-64  lvcompare  lvmerge                  niPythonInterface
(1,274 Views)
Accepted by topic author alucky
The server is /usr/bin/nirioserver.  The ini file is in /var/lib/nirio/ini.
https://www.ni.com/pdf/manuals/ni-rio-2023-q3-linux.html#usingRIOServer
(1,267 Views)
Hi, GabeJ
Thank you, for your help.
I didn't notice because I was only looking at old information.
(1,247 Views)
You're welcome.  Newer releases don't seem to have readmes, so sometimes the right info is hard to find.
(1,231 Views)
