Linux Users
openSUSE 11.2 and NI-KAL
I have to reinstall openSUSE and I thought I might try release 11.2. Therefore a question: has anyone tried it? Does it work with LabVIEW 2009 and in particular with NI-KAL 1.10? Thanks!
(5,898 Views)
NI-KAL 1.10 will not install out-of-the-box on openSUSE 11.2.  First thing is that the init_mm symbol is finally not exported and breaks compilation.  We have also found that by simply re-exporting init_mm you will still get crashes in normal operation.  So far we don't have any more information than that.
(3,946 Views)
I am in the exact same boat.  I found that I had to download the 2.6.28.10 kernel from www.kernel.org and compile my own kernel.  It allowd NIKAL 1.10 to build successfully.  Note that NI-DAQMX 8.0.1 comes with NIKAL 1.09 built-in and you have to get NIKAL 1.10 separately.
IIRC this was the order of operations:
1. Successfully build 2.6.28.10 kernel
(Basically I copied the config file from the stock 2.6.31 kernel in OpenSUSE 11.2 and pared it down a bit)
2. Install NIKAL 1.10
3. Install NI-DAQmx 8.0.1 (it will detect the presence of NIKAL 1.10 and not try to install 1.09)
4. Run updateNIdrivers so that the NI-DAQmx drivers are rebuilt against NIKAL 1.10
How easy you find this will depend on your experience.
(3,946 Views)
