Linux Users
Showing results forΒ
Search instead forΒ
Did you mean:Β
[solved] NI-VISA wrong ELFCLASS on gentoo
Hello all,
i'm new to the user group and not an expert of Labview. I'm trying hard (for two days now) to install Labview on a gentoo multilib distro. I've removed and reinstalled all the stuff for several times now and I'm running out of new ideas of howto install labview. It should run together with a PCI 6229 - Card.
I've started with NI-VISA 17.0.0 for Linux.
The installationprocess did finish. I've updated the kernelmodules, and they are all loaded.
Here is lsmod:
Module                  Size  Used by
nipxifpk               53978  0
nipxigpk               13306  0
nipxirmk              278376  2 nipxifpk,nipxigpk
nimxdfk               419927  2 nipxifpk,nipxigpk
nimdbgk               300916  4 nipxifpk,nipxigpk,nipxirmk,nimxdfk
NiViPciK               70373  0
NiViPxiK               17909  0
nidimk                310569  2 nipxirmk,NiViPxiK
niorbk                 64537  6 nipxifpk,nipxigpk,nipxirmk,nimdbgk,nimxdfk,nidimk
nipalk                909346  9 nipxifpk,nipxigpk,nipxirmk,NiViPciK,NiViPxiK,nimdbgk,nimxdfk,nidimk,niorbk
nikal                  65240  9 nipxifpk,nipxigpk,nipxirmk,NiViPxiK,nimdbgk,nimxdfk,nidimk,nipalk,niorbk
1) Problem
Running visaconf I get the following error message:
Can't load library /usr/local/lib/liblvrt.so.15.0
/usr/local/lib/liblvrt.so.15.0: wrong ELF class: ELFCLASS64
To download the LabVIEW Runtime engine, go to http://www.ni.com/rteFinder?dest=lvrte&version=15.0&platform=Linux&lang=en
Well, it tells me to install LabVIEW2015RTE_Linux.tgz. I did this in my first installation cycle, but the error stays the same.
Any hints on this ?
Smiley Happy Please have a look at the spoiler, there is an update:
Spoiler
64bit Libraries are stored in /usr/local/lib/LabVIEW-2015-64/
the links found by ls -l in /usr/local/lib were pointing on the 64bit variant:
lrwxrwxrwx 1 root root 15 Jan 19 12:21 liblvrt.so -> liblvrt.so.15.0
lrwxrwxrwx 1 root root 33 Jan 19 12:21 liblvrt.so.15.0 -> LabVIEW-2015-64/liblvrt.so.15.0.
so I removed liblvrt.so.15.0 and made a new link within /usr/local/lib/ using:
ln -sf LabVIEW-2015/liblvrt.so.15.0.1 liblvrt.so.15.0
visaconf is up and running πŸ˜‰
2) Problem
Running lsni64 gives:
Scanning localhost for devices...
libnipalu.so failed to initialize
Perhaps you need to run updateNIDrivers
Aborted
I've found a 32bit version an 64bit version:
/usr/lib64/i386-linux-gnu/libnipalu.so
/usr/lib64/i386-linux-gnu/libnipalu.so.1
/usr/lib64/i386-linux-gnu/libnipalu.so.17.0.0
/usr/lib64/x86_64-linux-gnu/libnipalu.so
/usr/lib64/x86_64-linux-gnu/libnipalu.so.1
/usr/lib64/x86_64-linux-gnu/libnipalu.so.17.0.0
/usr/local/natinst/nipal/lib/libnipalu.so.17.0.0
/usr/local/natinst/nipal/lib64/libnipalu.so.17.0.0
 Smiley Happy Please have a look at the spoiler, there is an update.
Spoiler
UPDATE:
I had to start: /etc/init.d/nipal start ... This gave me:
lsni64 => ...
System Configuration API resources found:
/sys/bus/pci/devices/0000:04:05.0
/sys/bus/pci/devices/0000:04:06.0
sunnyboy03
ASRL1::INSTR
Again, any hints on this ?
I did no go any further with the installation during my actual cycle of the installation procedure cause I can say this will not  change if I will install Labview 2015,  nidaqmxbase-15.0.0 and LabVIEW2015RTE engine, as I did in the installation cycle before.
I hope, you can give me any hints πŸ˜‰
Have fun,
kaffeesurrogat
(4,151 Views)
Hello, any chance to use CENTOS 7.4?
For me this is the best linux with labview.
Please let me know.
(4,134 Views)
Hey vphino13,
this might happen one day, right now I don't want to give up πŸ˜‰
Cheers,
Kaffeesurrogat
(4,116 Views)
Hello All,
i've added the solutions to the spoilers in the first message πŸ˜‰
Have fun,
kaffeesurrogat
(4,113 Views)
