London LabVIEW User Group
A quick update for the Flappy Bird project
It seems last post was found by @labview and brought much visiting here. So this project is still undergoing and I was kind of busy this month. But I will try finish this ASAP  :)
Here are some updates since last post.
An Arduino controlled stylus now can be controlled by  clicking the mouse.
LabVIEW - Motor Control - Austin Consultants Flappy Bird Project
There is a tip that the stylus needs to be earthed (via the red wire) to take affect.
And the Flappy Bird game is (poorly) simulated on LabVIEW. So I simulated FB (not facebook!) on LabVIEW to test the Q-learning algorithm in a purely software environment. Now it can pass 5 gaps  :) The algorithm needs to be altered a bit and then I will integrate the whole things.
LabVIEW - Austin Consultants Flappy Bird Project - SW Simulation
Dr Bo Fu is a Certified LabVIEW Developer and joined the Austin Consultants team in December 2013 as a Systems Engineer. Dr Fu joins us from the University of Nottingham where he completed his PhD and did a Postdoc in Electronic Engineering, developing a high-speed dynamic-sampling camera and a real-time control spatial light modulator. You can read more of his LabVIEW updates on his blog.
Message 1 of 1
(5,161 Views)
