London LabVIEW User Group
LabVIEW Tip: Adding a graph to a LabVIEW front panel
Bar charts are always handy and are the staple of Microsoft Excel. However, in LabVIEW they are not immediately obvious, but adding a graph to a LabVIEW front panel is easier than you think. This tip also includes adding graphs.
  1. Right click on any of the plots located on the plots box.
  2. Select common plots. You will then be able to browse for bar charts.
  3. You will probably want to make the line thicker. This can also be done by right clicking on the plot.
Got a LabVIEW Tip of your own that you would like to share? Leave a message in the comments below or head over to our Facebook Page and leave us a message! If you would like to receive a new LabVIEW Tip each month directly to your inbox, follow this link to subscribe to our monthly newsletter!
The post LabVIEW Tip: Adding a graph to a LabVIEW front panel appeared first on Austin Consultants.
Message 1 of 1
(6,447 Views)
