London LabVIEW User Group
LabVIEW Tip: Custom Wire Appearance
LabVIEW Object-Oriented Programming (OOP) gives a lot of versatility and power to your LabVIEW code. It also gives you the perk of defining custom wire appearances for your LabVIEW class (*.LVClass file).
All you need to do is: Right click *.lvclass >> Select Properties >> Select Wire Appearance.
Here you can change the Pattern, colours and size of your wire.
LabVIEW Tip: Customer Wire Appearance
Got a LabVIEW Tip of your own that you would like to share? Leave a message in the comments below or head over to our Facebook Page and leave us a message! If you would like to receive a new LabVIEW Tip each month directly to your inbox, follow this link to subscribe to our monthly newsletter!
The post LabVIEW Tip: Custom Wire Appearance appeared first on Austin Consultants.
Message 1 of 1
(5,651 Views)
