London LabVIEW User Group
LabVIEW Tip: Quick Bold Text
Want to get bold text without navigating the menus? Then add “QuickBold=True” (without the quotes) to your LabVIEW INI file.
LabVIEW Tip: Quick Bold Text, by Austin Consultants
Detailed explanation: Ever wanted to quickly make some text in a comment or on your front panel bold? Have you hit CTRL-B like in Word or Outlook, and absolutely nothing has happened? Then this tip is for you! It works by turning on an unofficial feature that we’re hoping gets promoted to full release LabVIEW, however for now just add the token to your LabVIEW.ini (found in the same folder as the LabVIEW.exe) and CTRL-B to your heart’s content. You can vote for this to become a proper feature in the  Idea Exchange.
Note you will lose current CTRL-B functionality (remove all broken wires) until this idea is properly implemented.
Want to receive our LabVIEW Tips via email each month? Drop an email to info@austinconsultants.co.uk with ‘Subscribe’ in the subject heading and we’ll add you to our mailing list.
Message 1 of 1
(5,604 Views)
