London LabVIEW User Group
LabVIEW Tip: Replace waveform attributes for sensible names on waveform graphs
If your DAQ subsystem knows what the engineering channel name is, overwrite the channel name after getting the waveform data from DAQmx. The waveform data type carries that attribute throughout your system and any graph attached to that waveform will automatically label the channels correctly.
LabVIEW Tip: Waveform Graph Name Change
Message 1 of 1
(5,186 Views)
