Lookout
AB MicroLogix 1100
I am in the process of replacing the RTU hardware at a Water Treatment Facility. I plan on using the AB MicroLogix 1100 as the core RTU. These would be connected via wireless ethernet radio units.
I received my first ML 1100, programmed a quick test program, and attempted to connect it to the Lookout program. I am using version 4.0.1. The Water Treatment Facility project is using version 5.0. I could not get proper communication. I have tried every configuration, but I have not had any success.
I found this form and have reviewed previous messages and answers to the ML 1100 connect issue. These were in 2006.
My question, does the new 6.1 version address the ethernet TCP/IP connectivity with the ML 1100?
I would appreciate correct information on this before I upgrade to the version 6.1 and then find out that it did not solve this ML 1100 ethernet TCP/IP driver problem.
Thank you for your view,
(7,506 Views)
We are working on the driver issue. We are going to support more PLCs and provide better performance. But currently Lookout 6.1 doesn't support MicroLogix 1100 via Ethernet. At least, the AB objects don't work.
You can use a 3rd party OPC Server, such as Kepware or the one from AB.
Ryan Shi
(7,489 Views)
Thank you Ryan,
I appreciate your very quick response. I also appreciate that National Instruments is always working to improve their products.
mgp64
(7,484 Views)
Does the same applies when you want to use AB drivers for web server applications? I'm asking because I'm constantly getting error „this object will not run in client version of lookout: AB1“ when I try to export webserver files.
Is there solution to avoid this error?
Thanks!
(7,414 Views)
You cannot export the driver objects, including AB driver, to the web client.
The driver object can only run in server process. All communication with devices are done by server process. The web client talks to server. That's why you got this error.
Take a look at Lookout Developer's Manual. Chapter 12.
Ryan Shi
(7,411 Views)
Has this issue been resolved in Lookout 6.7?
(5,208 Views)
