Lookout
Active X
Hi All,
I am trying to use active X controls upon opening the process I keep getting the message -
" The object is not bindable or is part of the control ! "
Does anybody know why this is ???
A detailed reply would be very much appreciated
(3,786 Views)
Forgot to add the attachment
(3,781 Views)
  what exactly is your setup as you try to build up the control? The CWKnob (so the dials you're using) have the ability to be bound to data, and I'm wondering if this is the actual error you're seeing.
If you have a look at the properties for the dials, then there's a bindings tab, and you have a binding on each of those dials, but I couldn't see what you were trying to actually bind to (the value is the normal one, or a pointer) but the value is being automatically bound to
Hope that helps.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,746 Views)
