Lookout
Animation - Can I use an expression (event based) to display an Animation? - New User
I am bench testing my application with a DL05. This has been a great way to learn the Lookout application. Ex: PB, high/low bit conditions representing the same PB's color and text state (PB object with no text description, just color background and with it use a logical expression with text and transparent background). Also, multi state text and background color representation using only logical expressions. This way I do not have to develop bitmap graphics (only have the coloring book MSPaint) for text with variable background color.
Animations: I need the animation (condensor fanpic1 - which I have rotating with a green background - 1 row 4 columns ) to appear upon a Y2 high bit and not visible upon a low. Also, on the Y2 low bit (condensor fanpic2 - which is not rotating with a gray background - using multistate low = condensor fanpic2 high = null graphic) visible. I have tried several scenarios in trying to make animation (condensor fanpic1) not visible/transparent. No succes. It (condensor fanpic1) is always present regardless of high/low state.
I have tested live communications between PB's, pumps, texts, and variable numeric diplays and inputs to various dicrete and Vmemory addresses. K-Sequence protocol. Working well.
Please help,
Brad
(6,603 Views)
You are tring to hide the Animator object correct? In the animation tab in properties, there is an expression field for visible.
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(6,601 Views)
Yes. So obvious and simple, duh! With your help. The visible tab works great for the animation.
I should have seen that. Here is probably another obvious one for you concerning the same concept. I want the non rotating (condensor_fanpic2) to be visible when Y2 is low.
I first tried with a Display Multistate if: PLC_RS232.Y2=0 and (graphic space) = condensor_fanpic2; Else if:PLC_RS232.Y2=0 and (graphic space) = null. It remains not visible, regardless.
A Logical Expression however works: PLC_RS232.Y2 ON = null and OFF = condensor_fanpic2 visiblility and non-visibilty works great. Opposite state with my animation visibility and non-visibility.
Why won't a Display Multistate described above work with just 2 discrete states assigned?
Brad
(6,598 Views)
For a 2-state display dont use the multistate, more memory intensive.  Create an Expression, for the On and Off Display use Custom.
In the multistate is there a graphic selected for "Else"?
Mike
(6,596 Views)
Another duh! That makes complete sense, once I tried a memory address and put whatever graphic per PLC_RS232.V100=0-4 at each bit. Can't use it as a 2 state with a discrete.
I forced each bit at V100, one at a time, and each graphic displayed correctly.
Thanks again,
Brad
(6,592 Views)
No problem, good luck on the project.
Mike
(6,589 Views)
