Lookout
Any idea on what is causing my serial ports to lock up?
I recently purchased the NI serial-usb 4 serial port interface box because I was having a problem of my serial ports locking up, and I thought the problem might be with my serial port card. Well, after a few days with the NI boxes 2 of my serial ports locked up. This is a big problem that I need to get resolved. If anyone has any ideas on what might be causing this please let me know.
I am running Lookout 5.0 (build 7) and Logos 4.4.0.17 on a Dell Windows XP machine with 1GB RAM and a 2 GHz processor. I have already tried recompiling my Lookout file and clearing out my database but the problem still occurs. If I restart the file then the ports start working fine again, but I need to know what is causing this since this
wasn't a problem until about 2 months ago.
Any responses would be greatly appreciated.
Jason
Jason Phillips
(3,397 Views)
Do you have ANY other programs running in bkgrnd like,
pcAnywhere or any PDA desktops like ActiveSync or Palm. What about communication programs for PLC's like RSLinx (Allen-Bradley) or Telepace (SCADAPack) programming s/w??. What about a telephone modem vying for the same Com port. Are you using Com1 or Com2. It may be necessary for you to obtain a Serial Port Card like "Blue Heat" www.connecttech.com/sub/Products/BlueHeatPCI_RS232.asp
Hope this helps!
Ben Gray
(3,397 Views)
Thanks for the response, Ben.
I have Laplink running on the computer all the time, and we do have 2 SCADA packs in the field at this time, but I don't run the Telepace program on this computer. This computer does not have a modem. As far as the serial port card, I was using a "Byterunner" 4 serial port card but I purchased the NI 4 serial port -usb interface because I thought the byterunner card might be the problem.
Do you think Laplink could be causing the problem?
Jason
Jason Phillips
(3,397 Views)
