Lookout
Archiving of database fails at 95%
Ryan,
I was able to archive the database in 2 parts. I then detached the original database and tried to move the files to another folder so I could replace the newly archived database with the original. But, when I do this the computer will not allow me to transfer the 2 mssql files from the folder of the original database. I get the "files cannot be moved" error. So, I tried to attach the newly archived database with the same mssql files from the original database but I do not get any trends when doing this.
Any ideas?
Jason Phillips
Message 11 of 16
(2,780 Views)
The alarm/event can also be archived. I think you only need to archive the 2 data parts to the new database, and all the alarm/event to the new database, then you just use the new database. In lookout, modify the database path.
Ryan Shi
Message 12 of 16
(2,769 Views)
OK. So I do not need to replace the original 2 mssql files with the new ones? What do those 2 files contain?
Jason Phillips
Message 13 of 16
(2,763 Views)
They are alarm/event database file. You don't need to manually copy those files. Just archive the alarm/event by MAX.
Ryan Shi
Message 14 of 16
(2,754 Views)
Ryan,
You mentioned a utility to repair a corrupt Citadel 5 database.  Could you please get that utility to me?
Ed
Message 15 of 16
(2,363 Views)
Ed,
I did use an utility to fix a specific corrupt problem in Citadel 5. But we have the fix in Citadel. The Citadel 5 now is able to repair this kind of problem automatically, so that utility is no longer useful. The Citadel with Lookout 6.1 and even 6.0.2 already has this fix.
I see another post from you about the XP SP3. Do you have Citadel problem with XP SP3?
Ryan Shi
Message 16 of 16
(2,349 Views)
