Lookout
AutomationDirect PLC ECOM communication with Lookout 6.7.1
We have a WIN XP ( NI lookout 6.0)  system that we are upgrading to WIN 7( NI LOOKOUT 6.7.1). The existing system has an H4-ECOM100 ethernet module connected to a network.  To make it work we purchased the AutomationDirect PC-DL-PLUS which is a driver for the NI Lookout.  The problem that has arised it that the PC-DL-PLUS driver was obsoleted in May of 2014 and will only run on Win XP and not WIN 7 as stated by AutomationDirect tech support.
Has anybody else run into this?  I bet NI did not bild this in since Lookout 6.5.This driver made every thing to set up.  I have looked at OPC drivers but this will cause a lot of re-work in upgrading the system.
I know Lookout is a 32 bit package, but has any body run this on Win 7 64 bit?  Our conpany buys 64 bit hardware / OS at this time. NI states it will not run on a 64bit system, even when installed in x86 mode
Thanks in advance,
Michael
(5,462 Views)
ECOM100 supports Modbus TCP, use the modbus driver.
If you used Data Member Aliases for the development, creating a new driver with the aliases may not be too much work.
Forshock - Consult.Develop.Solve.
(5,431 Views)
I had the same problem for long time. after lot of work I findout this solution. It is working in my laptop running win 7/64, but I don´t know how steady it is because not run for long time connected to PLC. I am developer .
Try this and let me know the results to maguerrero@icp.com.do.
1-. Install Lookout in Lookout x.x directory.
2-. Install DirectLogic plus in Lookout directory. It will create two directory, Lookout and DirectSOFT5.
3-. Copy all files from DirectSOFT5/BIN directory (created in step 2) to Lookout x.x directory (created in step 1) .
4-. Uninstall DirectLogic Plus and delete DirectSOFT5 directory (created in step 2) . If ask to reboot computer, do it.
5-. Rename Lookout x.x directory (created in step 1)  to BIN.
6-. Install DirectLogic Plus again in directory Lookout.
7-. Copy DSComm4.cbx and Meter.cbx from Lookout (created in step 6) to BIN (created in step 5).
8-. Rename BIN directory (created in step 5) to Lookout x.x .
9-. Reboot computer and run lookout.
(5,273 Views)
