Lookout
Average Object in Lookout
Hello folks, I need an assistance.
Can I run average object (Lookout 6.0.2) for calculate the average of a variable that changes its value 20 times per second, during 10 to 20 seconds?
In other words: The result of the average calculation of a variable that changes its value 20 times per second will be a valid number if the average object is reset every 20 seconds? There will be 400 values (samples?) as source for average calculation.
The object help wasn't too explicit.
Any comment will be appreciated.
(3,385 Views)
The internal timer of this object is hard-coded. The frequency is 1hz......
So, the max sample rate is 1hz, which means it can only sample and calculate 1 data update per second, even if you connect a 20hz pulse to "Enable".
Sorry.
Ryan Shi
(3,376 Views)
