Lookout
Brooks 5850s RS485 Hart Driver
Hello to all,
I'm looking for a lookout 6.2 driver to comunicate with an array of mass flow controllers by Brooks.
I've found a driver but for labview.
I wonder if i can use it under lookout and how ?
Thank you for your help.
(6,519 Views)
Build a small LabVIEW executable with shared variables representing the data, then Lookout can grab them from the same PC or another PC.  Also, depending on the model, many Brooks MFC's have RS-485 built in which would allow you to use ASCII, Modbus or other Lookout drivers.
Ed
Message Edited by erblock on 04-10-2009 01:31 AM
(6,494 Views)
