Lookout
CB-50LP with 6025E
Looking to use an existing setup with a slightly newer PCI card.  Just wondering how I can setup PCI-6025E to work with accessory CB-50LP when it is not in the list of Accessories when setting it up?  If None is selected for accessory, will it work?
Going from PCI-1200 to 6025e with the adapter.  Just wondering what to do with the accessory setting.
(3,535 Views)
Hi, it seems that you are not using Lookout, what software are you using?
(3,484 Views)
