Lookout
COMMUNICATIONS BETWEEN LOOKOUT 5.0 AND AB SLC 5/03 ON 3002 VOICE GRADE LEASED LINE
I AM HAVING TROUBLE GETTING PROPER COMMUNICATION BETWEEN LOOKOUT 5.0 AND AB SLC 5/03 PLC ON A 3002 VOICE GRADE LEASED LINE USING LEASED LINE MODEMS.  I AM USING THE SERIAL PORT ON THE COMPUTER AND I HAVE CREATED AN AB SLC 5/03 DRIVER IN LOOKOUT FOR 1200 BAUD COMMUNICATIONS.  EVERYTHING IS OK.  SO I CREATED A SERIAL FILE TO VIEW THE ASCII DATA BEING TRANSMITTED IN AND OUT OF THE LOOKOUT.  I DO SEE DATA GOING OUT AND TRYING TO GET BACK, BUT IT IS SCRAMBLED.  THERE IS NO CONSISTANCY.  SOME DATA GETS CHOPPED OFF.  I RECEIVED ERROR MESSAGES  "NO RESPONSE - NO ACK FOR OUR TRANSMISSION" AND "RECEIVED TNS DOES NOT MATCH".  THESE ERROR MESSAGES TOGGLE DEPENDING ON HOW I ADJUST THE GAINS ON MY MODEM.  I NEED HELP.....  ANY ADVICE WOULD BE APPRECIATED.  THANKS.
Message 1 of 1
(3,292 Views)
