Lookout
CW Slide Control
I'm attempting to use the Active X Slide control in Lookout 5.0. I have set the slide control up as an indicator. I have 3 data points that i would like to display. I set up Pointer-1, Pointer-2 and Pointer-3. Pointer-1 is the User Configurable High Level Alarm. Pointer-2 is the User Configurable Low Level Alarm. Pointer-3 is the actual value of the Analog value coming in on from the field. How do I "connect" to the select Pointer to change the values or display the values?
(3,253 Views)
Ollie,
currently there is no way to get to the ActivePointer.value property with Lookout 5's ActiveX container. The Lookout 5 ActiveX container does not allow to browse into property folders to get a dataitem e.g. CWSlider1.properties.ActivePointer.Index or CWSlider1.properties.ActivePointer.Value (CAR ID: 2VK7F6E9)
You might use Microsoft Visual Basic to wrap the CWSlider ActiveX control into a customized control you can use as advanced control in Lookout. Here is a link that might help further: Lookout Version 5.0 for Windows 2000/95/98/ME/NT/XP -- ActiveX Control Development Guide
Hope this helps
Roland
(3,253 Views)
