Lookout
Can I use FP-DI-AC120 with Lookout 4.01
I'm trying to use FP-DI-AC120 and FP-DO-AC120 modules with Lookout ver. 4.01 and it doesn't work. I can access both modules using Fieldpoint explorer but not in lookout. Do I need to upgrade to a newer version of Lookout?
(2,901 Views)
You have two several options that you can use. First, although I am not sure which version of Lookout first supported this, you can use the TBAI, TBAO, TBDI and TBDO data members. If the fpoint.cbx in Lookout 4.0.1 does not support these members, you have two other options. If you are using ethernet modules you can connect directly to the ethernet module and access the channels. For more information on this approach please see the following (note: the article talks about datasockets but using Object Explorer provides the same hierarchy & URL's):
http://zone.ni.com/devzone/conceptd.nsf/webmain/A6617392B393C4B886256ACB0053AEBE?opendocument&node=DZ52425_US
Finally, you can use the FieldPoint OPC server with the Lookout OPC client to access the FP-TB-10 modules.
Regar
ds,
Aaron
LabVIEW Champion, CLA, CPI
(2,901 Views)
