Lookout
Can I use integrator software to change and compile older runtime versions.
I have several clients with older versions of lookout runtime HMIs on their machines and support from the OEM is very poor.  Can I use the Integrator version of Lookout to make changes to these older (Ver 3.8 so far) HMIs and compile them to run without upgrading the runtime?
(5,633 Views)
Only if the Integrator version is the same.
4.0-5.1 are very similar, minor changes.  Can upgrade to 6.x easily enough
6.0-6.5 similar as well. Cannot be down-graded to 5.1 easily.
Good luck,
Mike
Forshock - Consult.Develop.Solve.
(5,617 Views)
