Lookout
Can I use lookout to retreive data in CSV file stored at a network PC
The machines I try to interface are PC based machines and network capability. All the informations are stored in CSV files.Is it posssible to use lookout to read these CSV files periodically.
(3,734 Views)
Lookout does not have built-in functions to read CSV files. However, their are some ODBC drivers that are capable of reading/writing text files, and you can use Lookout's SQLExec object to communicate with those ODBC drivers. For example, the Microsoft Text Driver in your ODBC control panel will let you do this.
Greg Caesar
National Instruments,
(3,734 Views)
