Lookout
Can Lookout 6.2 save files as an older version?
Can Lookout 6.2 save files in a format that can be used by older versions - i.e 5.1?
(6,139 Views)
No, incompatible.
From 5.1 to 6.2 yes.
Mike
Forshock - Consult.Develop.Solve.
(6,135 Views)
Afraid of that....  what about exporting objects such as screens/windows?
thanks
(6,130 Views)
Can be done, have to use a text editor (notepad) and select the source from the LKS.  If I remember correctly, there are some minor syntax changes.  The compile will tell you.
Good luck!
Mike
(6,122 Views)
