Lookout
Can Lookout 6.7 open, allow editing, and then save programs written in previous versions of Lookout like 4.2 or 5.1?
I have several control stations provided by a 3rd party that need some tweaks made to them, however if I purchase Lookout, I will receive a much later version than they were originally written in.  I do not want to change the OS the stations are using so would like to save the applications in their original version.  Is this possible?
Thanks!   Barney Rubble
(5,319 Views)
Contact NI directly, they may be able to help.
If not I can get you the Install for Lookout 5.1 relatively easily.  It will run in eval and may be enough to get you in to make some changes.  I do not have 4.5 or older.
Forshock - Consult.Develop.Solve.
(5,249 Views)
