Lookout
Can applications running on Lookout V3.8 be imported into V6.1
We currently have Lookout V3.8 running on NT PC's.  We need to replace the hardware and want to consider upgrading to V6.1.  Is it also possible to consider keeping the same version on an XP build?
(6,401 Views)
Do you want to use Lookout 3.8 on XP? Officially 3.8 doesn't support XP. It will probably work on XP, but we have not done any tests. Our suggestion is to upgrade because of the uncertainty.
Ryan Shi
(6,390 Views)
Does the application from V3.8 import into V6.1 without issue?
(6,385 Views)
Accepted by topic author fordste
There should be no issue, but several things you need to know. See this manual, Compability and Conversion Issues on page 12.
http://www.ni.com/pdf/manuals/371384a.pdf
Ryan Shi
(6,382 Views)
