Lookout
Can lookout 5.1 be used on Windows 7?
Lookout 5.1 is not working on Windows 7. What can be done? Please inform the installation steps.
(6,598 Views)
From my understanding, versions below 6.0 are NOT compatible with Windows 7.
Jason Phillips
(6,595 Views)
If this is Windows 7 Professional, Enterprise or Ultimate.  Use the XP Mode and create a virtual machine.
I would recommend VMWare Workstation, it is a very stable and powerful.
Good luck,
Mike
Forshock - Consult.Develop.Solve.
(6,566 Views)
I had the same problem before. I tried XP mode but seems not working. I finally upgraded the Lookout to 6.6 and it works.
(6,538 Views)
Then you have to get a new license for Lookout 6.6?
I have the same problem; I use Lookout 6.0.2 but I would like to start the migration to Windows 7. I have received the installation Discs of Lookout 6.6, but I don't know if the same serial number I have for the development 6.0 will work for getting a license for 6.6.
Does any one knows any workaround for this issue?
(6,451 Views)
Serial for 6.0 will not work for 6.6
Upgrade would be required.
Message 6 of 5
(6,442 Views)
