Lookout
Can lookout control C series modules?
Greetings,
I was wondering if Lookout had the ability to recognise dataAq modules( i.e. NI9205, Ni9265). I have a solenoid that opens or closes a valve using a 4-20 current loop.
i sense position with a 4-20 analog input module from Biel-Wiedmann. Both devices are controlled through a modbus gateway. I am looking for something more flexible
than this dedicated hardware I have to build up to convert Asi-Modbus address enables to 4-20 outputs and inputs. Is labview the better choice?
thank you,
JohnG.
(5,877 Views)
I think LabVIEW is better choice to control the NI DAQ card.
Ryan Shi
(5,869 Views)
