Lookout
Can't get Lookout 5.1 to run under Windows 7.
Hello, I'm trying to run Lookout 5.1 on Windows 7. I've installed it and tried different compatibility settings and it just starts and hangs. I have to kill it in the Task Manager. I looked under Services and the National Instruments Time Synchronization was set to OFF and MANUAL. I started it and tried to run Lookout again and it didn't act any different. Is there any special tricks to get Lookout 5.1 to run under Windows 7?
Thanks.
SCADA Programmer at the Coachella Valley Water District.
(5,940 Views)
I think that you have to install first VMware in Windows 7 (XP Mode), have full administrator rights, and know what you doing.
Even so,I doubt that an old Lookout release will work with Windows 7. Lookout database is going to be a major problem.
There is a new Lookout 6.5 that was designed for Windows 7.
(5,850 Views)
