Lookout
Can you force a value into a read-only numeric data member?
I have code that will force a value into a numeric data member. Unfortunately the numeric data member in question is read-only. Can you force a value into a read-only numeric data member?
(3,184 Views)
No, unfortunatelly the read only numeric data members are not meant to be written to. The simple fact of trying to connect will give you error and your code will not run properly.
Best Regards
Andre Oliveira
(3,184 Views)
Andre,
I think you should get together with the other engineers there at NI. I spoke to one on the phone yesterday and he told me that the read-only aspect relates to writing between the database and PLC. I'm trying to write to the database and he told me that I could do it.
(3,184 Views)
