Lookout
Can you password protect the edit mode?
I want to run a developers suite so that you cannot enter the edit mode without entering a password?
(3,172 Views)
Edit mode is available to security level 9 and above.  Create an account for non-editing below 9 and another account 9 (or above) for editing.  Select the user name which you wish to be default, check the "Set as default login user" button, and click OK.  This will be the ‘default’ login at startup.  More info on security is in the on-line help.
(3,168 Views)
