Lookout
Cant see server computer from client
I have a server process with 4 client processes. I can see all the computers in the object explorer from any process, and all process are running fine, but when I tried to syncronize the clocks on the clients, I can't see all the other computers(only three).
(3,080 Views)
Hello Scott,
When you access Time Synchronization from Options of Lookout, you will not see any computers immediately. You will have add the server computer to which you want the client to be synchronized with. So in the client computer running Lookout, go to Options>Time Synchornization and add the server computer name to it. This way you can make all the clients to be synchronized to the server computer.
Arun V
(3,073 Views)
