Lookout
Changing text color in lookout
I wish to display a read only fieldpoint value (like a temperature/thermocouple input)and have the text colour change based on some condition (i.e. green when temp < setpoint, red otherwise) - how do I do this? Again; this is a read only value. Thanks.
(3,474 Views)
I do this with multiple expressions each formatted with a different color on the panel. For example:
Expression #1: IF(Driver.Analog<10,Driver.Analog,"")
Expression #2:IF(Driver.Analog>10 AND Driver.Analog<20,Driver.Analog,"")
Expression #3: IF(Driver.Analog>20,Driver.Analog,"")
Expressions 1,2, and 3 would be formatted with different colors. The if statement with the null output when the condition is false ensures no two expressions are visible at the same time.
Tommy Scharmann
(3,474 Views)
You can use the Gauge object for this.
Create the Gauge object and specify for the Signal parameter your input signal, e.g.,
Signal = PLC1.temp
You can now choose several IF-Else states and colors for them. For e.g.,
If = PLC1.temp > 90 <(say, red)
and so on.
Once you're done defining the conditions and their colors, hit OK.. and select Digital for Display style ('Bar' is the default).
This should do it.
Khalid 🙂
(3,474 Views)
