Lookout
Citadel data access from MS SQL Server?
I need to move Citadel data into SQL Server. Currently Query it into Access via ODBC and then import into MS SQL Server with a DTS package.
Can the ODBC source be queried directly from MS SQL and what would the syntax be. (Sample code would be really helpful 🙂
Thanks, gert
(3,380 Views)
Citadel is SQL compliant. Meaning that you need to use SQL commands and you should be able to read back from Citadel.
Ricardo S.
National Instruments.
(3,364 Views)
