Lookout
CitadelControl- resoration of data issues...
After I restore data to the active Citadel database using the CitadelControl object in version 4.5 a very peculiar thing happens. My hypertrends do show the traces for the time period of the restored data. However, if I click on the "cursor button" the path of the data does show in the "hypertrend cursor dialog box" but the value does not. Even if the vertical line is over a trace (no blank spots). Does anyone have any solutions to this???
Tommy Scharmann
(3,820 Views)
Tommy,
I have attempted the same exercise using Lookout 4.5.1 and do not observe the problem you are describing. I would like to see what happens when you attempt the same under 4.5.1. Please initiate a support service request and an Applications Engineer can assist you with getting 4.5.1
(3,820 Views)
