Lookout
Class not found: DirectLogic
I am trying to open an *.lks file developed with 4.0.1
in Lookout version 5.0 and I am getting the following
errors from the Compiler.
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(3): error: Syntax error
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(106): error: Class not found: DirectLogic
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(145): error: Class not found: DirectLogic
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(157): error: Class not found: DirectLogic
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(159): error: Class not found: D
irectLogic
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(106): error: Object is not defined: DLChemical
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(145): error: Object is not defined: DLCitty
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(157): error: Object is not defined: DLControl
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(159): error: Object is not defined: DLPump
C:\Program Files\National Instruments\Lookout 5.0\thomaswtp010811.lks(0): error: Invalid object pathname: 0
Does anyone have any ideas as to what may be the problem?
Regards
Steve
(3,250 Views)
Refer to the posting titled "DL205 Ethernet Upgrade to 5.0." Your answer is there.
Tommy Scharmann
(3,250 Views)
FYI, the post can be found a this link:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000007B620000&ECategory=Lookout
Cyril Bouton
Cyril Bouton
Active LabVIEW Developper
(3,250 Views)
