Lookout
Client Disconnected From Database
I'm running lookout 5.0 on one computer and logging its citadel to another machine. There is more than one lookout process on the PC that is actually running lookout itself. Different processes are logging to different designated database folders on the other computer. When you can actually get lookout to show the history info (i.e hypertrend data and such) on the computer it all works great. However if you ever restart the computer requiring to shutdown lookout, then the next time it boots up it is nearly impossible to get lookout to display the trend info again. You always get the "client disconnected from database" alarm. All the network paths and folder locations are correct. I am lost on this one.
(3,442 Views)
Did you get this error every time you reboot Lookout or sometimes ?
If you get it sometimes:
Simply delete the /database/ Folder in Lookout directory
when you restart Lookout it will creat a new one.
From experience when you get this message the database is realy damage
i dont know why this happens.
(3,368 Views)
