Lookout
Conversation of lower ver into ver 6.1
Hi Everybody,
As mention in subject, while converting lower version of lookout into higher version, I unable to find database. Please find attached screenshot.
Iftekhar
Transtech Projects
iftekhar_shaikh@transtechprojects.com
(6,224 Views)
Lookout 6.x uses Citadel 5 database, but Lookout 5.x uses Citadel 4. They are not compatible. Lookout tries to get the database in that folder, but it cannot find Citadel 5 database.
Follow this KB to convert the Citadel 4 to Citadel 5.
http://digital.ni.com/public.nsf/allkb/7F2CCB17675F1A0186257005006A6E21?OpenDocument
You'd better backup the database first.
Or if you don't want the old database any more, you can just configure your process to use the Citadel 5 database in Lookout 6.x folder. Or you can create new database in any folder by MAX, and use it.
Ryan Shi
(6,210 Views)
Thanks Ryan, It is now shows iopoints.:manvery-happy:
(6,206 Views)
