Lookout
Convert text string to numeric value in Lookout
Is there any way to extract a numeric value from a text string in Lookout? For example, I have a text string "<= 68.0 ppm" in an object, and I want to extract the value 68.0 as a numeric value for another object. I suppose I may need to strip characters or something, but the number start position and length are variables, so the mid(x,y) function does not work. I may be missing something obvious but any help would be appreciated.
(4,958 Views)
Is the character before the number fixed? If it is always ".....= XXX ppm", you can find "=" first and then use mid().
Message Edited by Ryan.S on 10-28-2007 09:30 PM
Ryan Shi
(4,936 Views)
