Lookout
Converting Lookout application to a different driver
I had some questions about the best way to migrate an existing Lookout application to a different communications driver. I am looking at changing from the current Applicom Profibus interface to an OPC Client. Can the Applicom ‘tags’ be changed to the OPC Client easily? Or would I have to recreate the ‘tags’, and then change the links in the screen and object configuration?
Message 1 of 1
(5,702 Views)
