Lookout
Data object in Lookout ver 5.0
I have a data object in Lookout ver 5.0 logging data at a rate of 1 sec.The application is already developed this way.Now I have a need to also log 10 second averages of all these points and log this points in Citadel DB.Is there a simpler way of doing this by a text editor?
(3,064 Views)
Please see this Example on how to implement a "running" average.
You basically will create an Expression Object and connect the "running" average to this. And enable historical logging on this Expression object.
Hope this helps.
Khalid
(3,064 Views)
