Lookout
Direct Logic drivers
I am using LookOut 6.0 with a Direct Logic 205 PLC and it will not let me select either of the direct logic drivers. The error is (The application has failed to start because Host 42.dll was not found.) I also tried re-installing and that did nit fix it. Any suggestions would be appreciated.
(4,866 Views)
DL Plus driver or DirectLogic driver?
Forshock - Consult.Develop.Solve.
(4,857 Views)
The Direct Logic Driver, It will allow an ethernet connection and I have used it on other projects. I was able to use the DL205 driver with serial cable on this particular project and it is working.
(4,822 Views)
