Lookout
Displaying Text from DL06 plc v-memory using DirectLogic PLUS driver
I have an Ascii string of text saved in v-memory on a DirectLogic DL06 plc and I'm trying to display that v-memory data member in Lookout using the DirectLogic PLUS driver for Lookout.  The value displays as a numeric value rather than text, even though I have the "display type" selected as text.  I also tried to create a "TextEntry" object and used the edit connections tool to set the "value" equal to the v-memory location and found the same thing... Lookout displays a numeric value instead of text.  Any ideas????
Message 1 of 1
(5,865 Views)
