Lookout
Does Lookout support password rules/complexity?
I am running Lookout 6.1 as the HMI for a SCADA system that is undergoing a security audit. HELP!
The IT person has asked how Lookout can be set up to use password rules. Currently if you enter "1" as the password Lookout will accept it.
Also is there a way to force a Logout or Lock the system after several unsuccessful Login attempts?
Any help or pointers would be appreciated.
(3,358 Views)
There is no built-in mechanism for such things...
I recommend atleast locking the workstation, that can help.  Set the timeout to a low value that will work.
There are many things that NI could add to Lookout... Hopefully the rumors are not true.
Good luck
Mike
Mike Crabtree - Lead Developer
Destek of Nevada, Inc. / Digital Telemetry Systems, Inc.
(866) 964-6948 / (760) 247-9512
(3,328 Views)
